[fdo-users] building FDO source code on Windows
Orest Halustchak
orest.halustchak at autodesk.com
Wed May 9 09:54:03 EDT 2012
That looks like an old note. You should use 10.0 or 9.3.1.
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Snehal Joshi
Sent: Wednesday, May 09, 2012 9:50 AM
To: FDO Users Mail List
Subject: Re: [fdo-users] building FDO source code on Windows
Hi Orest,
Thanks again for the helpful information. I've one last question that has been bothering me -
>From http://fdo.osgeo.org/files/fdo/docs/OpenSourceBuild__README.html, in Build Notes section, it says that in order to build the ArcSDE provider, you'll need to have the ArcSDE 9.1 client SDK installed. How strict is the version dependency? I see there is major release of ArcGIS software after 9.1.
Regards,
Snehal
On Wed, May 9, 2012 at 7:19 AM, Orest Halustchak <orest.halustchak at autodesk.com<mailto:orest.halustchak at autodesk.com>> wrote:
Hi Snehal,
I believe that's correct, that the sdk provides the necessary libraries. Make sure that you get the correct version of the sdk for 32 or 64 bit. I don't know if there is one sdk for both platforms or if there are separate sdk's.
Orest.
From: fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org> [mailto:fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org>] On Behalf Of Snehal Joshi
Sent: Tuesday, May 08, 2012 11:00 PM
Hi Orest,
Many thanks for your help. I've one more follow-up question -
Would the ArcSDE SDK installer also provide the SDE client libraries needed at run-time? (I'm assuming these are sg.dll, sde.dll, and pe.dll).
Snehal
On Tue, May 8, 2012 at 7:17 PM, Orest Halustchak <orest.halustchak at autodesk.com<mailto:orest.halustchak at autodesk.com>> wrote:
It uses the C API, which you can get from the ArcSDE SDK. You don't need the ArcSDE server just to build the provider, but you will need the SDE client libraries to run the provider.
Orest.
Sent: Tuesday, May 08, 2012 1:51 PM
To: fdo-users at lists.osgeo.org<mailto:fdo-users at lists.osgeo.org>
Subject: [fdo-users] building FDO source code on Windows
Hi All,
I am trying to compile FDO source code on Windows. From the build instructions, I figured I'd need to get ArcSDE SDK. I see there are two choices for this - the C-API or the Java SDK. I plan to build the FDO binaries to be used in C++ application. So, I'm assuming I could use the C-API. Is that a valid assumption. Also, do I need to have any additional ArcGIS/ArcSDE components installed the machine I use to build FDO code. I don't have ArcGIS/ArcSDE Server or Oracle on it currently. I have been struggling to get more information on this, and will greatly appreciate any pointers.
Many thanks!
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20120509/40a20a81/attachment-0001.html
More information about the fdo-users
