[fdo-users] building FDO source code on Windows
Snehal Joshi
snehal.joshi at gmail.com
Wed May 9 09:55:09 EDT 2012
Hi Orest,
Thanks very much, appreciate your help. I'll use one of the later versions.
Regards,
Snehal
On Wed, May 9, 2012 at 8:54 AM, Orest Halustchak <
orest.halustchak at autodesk.com> wrote:
> That looks like an old note. You should use 10.0 or 9.3.1.****
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Snehal Joshi
> *Sent:* Wednesday, May 09, 2012 9:50 AM
> *To:* FDO Users Mail List
> *Subject:* Re: [fdo-users] building FDO source code on Windows****
> Hi Orest,
> Thanks again for the helpful information. I've one last question that has
> been bothering me -
> >From http://fdo.osgeo.org/files/fdo/docs/OpenSourceBuild__README.html,
> in Build Notes section, it says that in order to build the ArcSDE provider,
> you'll need to have the ArcSDE 9.1 client SDK installed. How strict is the
> version dependency? I see there is major release of ArcGIS software after
> 9.1.
> Regards,
> Snehal
> On Wed, May 9, 2012 at 7:19 AM, Orest Halustchak <
> orest.halustchak at autodesk.com> wrote:****
> Hi Snehal,****
> I believe that’s correct, that the sdk provides the necessary libraries.
> Make sure that you get the correct version of the sdk for 32 or 64 bit. I
> don’t know if there is one sdk for both platforms or if there are separate
> sdk’s.****
> Orest.****
> *Sent:* Tuesday, May 08, 2012 11:00 PM
> Hi Orest,****
> Many thanks for your help. I've one more follow-up question - ****
> Would the ArcSDE SDK installer also provide the SDE client libraries
> needed at run-time? (I'm assuming these are sg.dll, sde.dll, and pe.dll).
> Snehal****
> On Tue, May 8, 2012 at 7:17 PM, Orest Halustchak <
> Hi,****
> It uses the C API, which you can get from the ArcSDE SDK. You don’t need
> the ArcSDE server just to build the provider, but you will need the SDE
> client libraries to run the provider.****
> Orest.****
> *Sent:* Tuesday, May 08, 2012 1:51 PM
> *To:* fdo-users at lists.osgeo.org
> *Subject:* [fdo-users] building FDO source code on Windows****
> Hi All,
> I am trying to compile FDO source code on Windows. From the build
> instructions, I figured I'd need to get ArcSDE SDK. I see there are two
> choices for this - the C-API or the Java SDK. I plan to build the FDO
> binaries to be used in C++ application. So, I'm assuming I could use the
> C-API. Is that a valid assumption. Also, do I need to have any additional
> ArcGIS/ArcSDE components installed the machine I use to build FDO code. I
> don't have ArcGIS/ArcSDE Server or Oracle on it currently. I have been
> struggling to get more information on this, and will greatly appreciate any
> pointers.
> Many thanks!****
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users****
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20120509/9f76c986/attachment.html
More information about the fdo-users
