[fdo-users] building FDO source code on Windows
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Wed May 9 09:57:24 EDT 2012
Hi Snehal,
I think this lik was not update since long time.
Below is a link for a readme which can be found in each FDO version and this is for trunk (3.8):
https://svn.osgeo.org/fdo/trunk/OpenSourceBuild__README.txt
Regards,
Romy
5. In order to build the ArcSDE 9.2 Provider, you will need to have the ArcSDE
9.2/9.3 Client SDK installed and the following environment variable
set to point to the ArcSDE SDK installation location:
set SDEHOME=[ArcSDE 9.2/9.3 Developer Components Path]
In order to build the unit tests for the ArcSDE 9.2 provider, set the following
environment variable value:
set SDEVER_ARCUNITTEST=92 - will build unit test using ArcSDE 9.2 SDK
In case user needs to build both the 91 and 92 versions of the ArcSDE Provider on Windows,
they will need to install both the ArcSDE 9.1 Client SDK and the ArcSDE 9.2/9.3 Client SDK,
set the environment variable SDEHOME to point to the location of the 9.2/9.3 Client SDK as
specified above, and copy the "bin", "include" and "lib" directory from the ArcSDE 9.1
Client SDK into: %FDOTHIRDPARTY%\ESRI\ArcSDEClient91\Windows
In order to build the unit tests for the ArcSDE 9.1 provider using the AcSDE 9.1 SDK,
set the following environment variable value:
set SDEVER_ARCUNITTEST=91 - will build unit test using ArcSDE 9.1 SDK
The ArcSDE provider build script will attempt to build both the ArcSDE 9.1 and 9.2 providers.
In case user has only one version of the ArcSDE client installed, the location must be
specified using %SDEHOME%.
NOTE: The ArcSDE unit test project will only search for include and lib files in %SDEHOME%
NOTE: ArcSDE is licensed software and must be obtained from an ESRI vendor.
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] on behalf of Snehal Joshi [snehal.joshi at gmail.com]
Sent: Wednesday, May 09, 2012 9:50 AM
To: FD.O Users Mail List
Subject: Re: [fdo-users] building FDO source code on Windows
Hi Orest,
Thanks again for the helpful information. I've one last question that has been bothering me -
>From http://fdo.osgeo.org/files/fdo/docs/OpenSourceBuild__README.html, in Build Notes section, it says that in order to build the ArcSDE provider, you'll need to have the ArcSDE 9.1 client SDK installed. How strict is the version dependency? I see there is major release of ArcGIS software after 9.1.
Regards,
Snehal
On Wed, May 9, 2012 at 7:19 AM, Orest Halustchak <orest.halustchak at autodesk.com<mailto:orest.halustchak at autodesk.com>> wrote:
Hi Snehal,
I believe that’s correct, that the sdk provides the necessary libraries. Make sure that you get the correct version of the sdk for 32 or 64 bit. I don’t know if there is one sdk for both platforms or if there are separate sdk’s.
Orest.
From: fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org> [mailto:fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org>] On Behalf Of Snehal Joshi
Sent: Tuesday, May 08, 2012 11:00 PM
To: FDO Users Mail List
Hi Orest,
Many thanks for your help. I've one more follow-up question -
Would the ArcSDE SDK installer also provide the SDE client libraries needed at run-time? (I'm assuming these are sg.dll, sde.dll, and pe.dll).
Snehal
On Tue, May 8, 2012 at 7:17 PM, Orest Halustchak <orest.halustchak at autodesk.com<mailto:orest.halustchak at autodesk.com>> wrote:
It uses the C API, which you can get from the ArcSDE SDK. You don’t need the ArcSDE server just to build the provider, but you will need the SDE client libraries to run the provider.
Orest.
Sent: Tuesday, May 08, 2012 1:51 PM
To: fdo-users at lists.osgeo.org<mailto:fdo-users at lists.osgeo.org>
Subject: [fdo-users] building FDO source code on Windows
Hi All,
I am trying to compile FDO source code on Windows. From the build instructions, I figured I'd need to get ArcSDE SDK. I see there are two choices for this - the C-API or the Java SDK. I plan to build the FDO binaries to be used in C++ application. So, I'm assuming I could use the C-API. Is that a valid assumption. Also, do I need to have any additional ArcGIS/ArcSDE components installed the machine I use to build FDO code. I don't have ArcGIS/ArcSDE Server or Oracle on it currently. I have been struggling to get more information on this, and will greatly appreciate any pointers.
Many thanks!
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20120509/c759bc5c/attachment-0001.html
More information about the fdo-users
