[fdo-users] building FDO source code on Windows
Snehal Joshi
snehal.joshi at gmail.com
Wed May 9 10:46:46 EDT 2012
Thanks for that pointer, Romy. Appreciate it!
Regards,
Snehal
On Wed, May 9, 2012 at 8:57 AM, Romica Dascalescu <
Romica.Dascalescu at autodesk.com> wrote:
> Hi Snehal,
> I think this lik was not update since long time.
> Below is a link for a readme which can be found in each FDO version and
> this is for trunk (3.8):
> https://svn.osgeo.org/fdo/trunk/*OpenSourceBuild__README.txt*<https://svn.osgeo.org/fdo/trunk/OpenSourceBuild__README.txt>
> Regards,
> Romy
> 5. In order to build the ArcSDE 9.2 Provider, you will need to have the
> ArcSDE
> 9.2/9.3 Client SDK installed and the following environment variable
> set to point to the ArcSDE SDK installation location:
> set SDEHOME=[ArcSDE 9.2/9.3 Developer Components Path]
> In order to build the unit tests for the ArcSDE 9.2 provider, set the
> following
> environment variable value:
> set SDEVER_ARCUNITTEST=92 - will build unit test using ArcSDE 9.2
> SDK
> In case user needs to build both the 91 and 92 versions of the ArcSDE
> Provider on Windows,
> they will need to install both the ArcSDE 9.1 Client SDK and the ArcSDE
> 9.2/9.3 Client SDK,
> set the environment variable SDEHOME to point to the location of the
> 9.2/9.3 Client SDK as
> specified above, and copy the "bin", "include" and "lib" directory
> from the ArcSDE 9.1
> Client SDK into: %FDOTHIRDPARTY%\ESRI\ArcSDEClient91\Windows
> In order to build the unit tests for the ArcSDE 9.1 provider using
> the AcSDE 9.1 SDK,
> set the following environment variable value:
> set SDEVER_ARCUNITTEST=91 - will build unit test using ArcSDE 9.1 SDK
> The ArcSDE provider build script will attempt to build both the
> ArcSDE 9.1 and 9.2 providers.
> In case user has only one version of the ArcSDE client installed, the
> location must be
> specified using %SDEHOME%.
> NOTE: The ArcSDE unit test project will only search for include and
> lib files in %SDEHOME%
> NOTE: ArcSDE is licensed software and must be obtained from an ESRI
> vendor.
> *From:* fdo-users-bounces at lists.osgeo.org [
> fdo-users-bounces at lists.osgeo.org] on behalf of Snehal Joshi [
> snehal.joshi at gmail.com]
> *Sent:* Wednesday, May 09, 2012 9:50 AM
> *To:* FD.O Users Mail List
> *Subject:* Re: [fdo-users] building FDO source code on Windows
> Hi Orest,
> Thanks again for the helpful information. I've one last question that has
> been bothering me -
> >From http://fdo.osgeo.org/files/fdo/docs/OpenSourceBuild__README.html,
> in Build Notes section, it says that in order to build the ArcSDE provider,
> you'll need to have the ArcSDE 9.1 client SDK installed. How strict is the
> version dependency? I see there is major release of ArcGIS software after
> 9.1.
> Regards,
> Snehal
> On Wed, May 9, 2012 at 7:19 AM, Orest Halustchak <
> orest.halustchak at autodesk.com> wrote:
>> Hi Snehal,****
>> I believe that’s correct, that the sdk provides the necessary libraries.
>> Make sure that you get the correct version of the sdk for 32 or 64 bit. I
>> don’t know if there is one sdk for both platforms or if there are separate
>> sdk’s.****
>> Orest.****
>> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
>> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Snehal Joshi
>> *Sent:* Tuesday, May 08, 2012 11:00 PM
>> *To:* FDO Users Mail List
>> *Subject:* Re: [fdo-users] building FDO source code on Windows****
>> Hi Orest,****
>> Many thanks for your help. I've one more follow-up question - ****
>> Would the ArcSDE SDK installer also provide the SDE client libraries
>> needed at run-time? (I'm assuming these are sg.dll, sde.dll, and pe.dll).
>> Snehal****
>> On Tue, May 8, 2012 at 7:17 PM, Orest Halustchak <
>> orest.halustchak at autodesk.com> wrote:****
>> Hi,****
>> It uses the C API, which you can get from the ArcSDE SDK. You don’t need
>> the ArcSDE server just to build the provider, but you will need the SDE
>> client libraries to run the provider.****
>> Orest.****
>> *Sent:* Tuesday, May 08, 2012 1:51 PM
>> *To:* fdo-users at lists.osgeo.org
>> *Subject:* [fdo-users] building FDO source code on Windows****
>> Hi All,
>> I am trying to compile FDO source code on Windows. From the build
>> instructions, I figured I'd need to get ArcSDE SDK. I see there are two
>> choices for this - the C-API or the Java SDK. I plan to build the FDO
>> binaries to be used in C++ application. So, I'm assuming I could use the
>> C-API. Is that a valid assumption. Also, do I need to have any additional
>> ArcGIS/ArcSDE components installed the machine I use to build FDO code. I
>> don't have ArcGIS/ArcSDE Server or Oracle on it currently. I have been
>> struggling to get more information on this, and will greatly appreciate any
>> pointers.
>> Many thanks!
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users****
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20120509/1f89549b/attachment.html
More information about the fdo-users
