[fdo-users] SDF3 display problem features
mdelsinne
mdelsinne at gmail.com
Tue Oct 9 03:11:47 PDT 2012
I seem to have found the solution:
The problem appears when I execute a command to delete many features and
then I execute an insert command. This should cause a problem handling
spatial index. To avoid this problem, between phases of deletion and
insertion, I disconnected (conn-> close ()) then I reconnect to the file via
the provider (conn-> open ()). SDF3 output file is correct.
Thank you.
View this message in context: http://osgeo-org.1560.n6.nabble.com/SDF3-display-problem-features-tp5007347p5007378.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
