[fdo-users] AutoCAD and FDO OGR for personal geodatbases
Jackie Ng
jumpinjackie at gmail.com
Fri Sep 14 07:04:03 PDT 2012
Firstly, look at the list of supported file formats here:
http://gdal.org/ogr/ogr_formats.html
Each format listed also tells you how an OGR application connects to it.
This is what you have to put in to the "DataSource" parameter of the OGR
provider connection.
Any format where compiled by default is not "Yes", you cannot connect with
the OGR provider because most likely, the gdal dll that comes with FDO is
compiled with default settings.
Also 64-bit applications cannot consume 32-bit libraries, this is why
AutoCAD cannot connect to access databases with a 32-bit driver. You must
have 64-bit access drivers
(http://www.microsoft.com/en-us/download/details.aspx?id=13255)
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/AutoCAD-and-FDO-OGR-for-personal-geodatbases-tp5001939p5001943.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
