[fdo-users] AutoCAD and FDO OGR for personal geodatbases
Brad Nesom
kidsmake6 at msn.com
Fri Sep 14 14:41:49 PDT 2012
Good point.
I am hpin gthat someone successful with filegdb rings in here to help us
get that first and second step going.
On Fri, Sep 14, 2012 at 2:59 PM, Traian Stanev
<traian.stanev at autodesk.com>wrote:
> One should not confuse "personal geodatabase" with "file geodatabase". The
> former is just an MDB file that OGR can read without extra SDKs installed.
> The extra SDKs would be necessary to read the latter, newer format (at
> least that's what I infer from reading the OGR docs - never tried file
> geodatabase myself).****
> Traian****
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Brad Nesom
> *Sent:* Friday, September 14, 2012 3:42 PM
> *To:* FDO Users Mail List
> *Subject:* Re: [fdo-users] AutoCAD and FDO OGR for personal geodatbases***
> That is what I found on Autodesk FDO help.****
> you would need to get licensing requirements from esri.****
> I do know that you must download the filegdb sdk and agree to the terms
> there.****
> If I am not mistaken at 2010 all the esri writers were disabled.****
> now at 2012 I think you can save to esri though I have not been successful
> doing that. or even getting the ogr provider activated so I could try.****
> brad****
> On Fri, Sep 14, 2012 at 12:21 PM, Bassler, Brian CTR NAVFAC MIDLANT, GIS <
> brian.bassler.ctr at navy.mil> wrote:****
> What is the license requirement for, to have save functionality? Because
> I'm able to open a personal and save to dwg without said license.
> Thanks for your reply,
> Brian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Friday, September 14, 2012 13:17
> To: FDO Users Mail List
> Subject: Re: [fdo-users] AutoCAD and FDO OGR for personal geodatbases
> To connect to personal and file-based Geodatabases, you must have the
> following:
> * A 32-bit operating system
> * Access to Personal and File Geodatabases
> * A valid license to either ArcGIS Desktop software or equivalent
> ArcEngine Runtime.
> ArcEngine is included with the ArcGIS Dektop products, such as
> ArcView, ArcEditor, and ArcInfo.
> On Fri, Sep 14, 2012 at 8:30 AM, Bassler, Brian CTR NAVFAC MIDLANT, GIS <
> Greetings,
> I have been working with the OGR provider available for AutoCAD
> and I have a few questions.
> First, is there a comprehensive guide to the use of the OGR
> provider?
> I'm currently using the 3.4 version with AutoCAD Map 3D 2010.
> I've not been able to save changes to a personal geodatabase regardless of
> the readonly setting when I connect or use of checkout/checkin from the
> ribbon. I have found contradicting info that says features can and cannot
> be edited with this plugin. Can I get a positive answer on this forum?
> I'm also working with a demo version of AutoCAD Map 3D 2013. I
> thought sure I had read somewhere that the OGR provider would be included
> in the install but it is not. I'm not sure which version I should try, so
> far have installed the 3.7 beta but am getting connection errors which I
> believe are due to the ODBC drivers present on my test machine. Said test
> machine is Win 7 64bit with 64bit AutoCAD 2013 and 32 bit Office 2007.
> Note that MS Access was not included in that install so I've also
> installed the 32bit ODBC connectivity drivers from MS. So far, this
> configuration DOES NOT work.
> I'd like to be able to use AutoCAD Map 3D 2013 to read/edit
> features in an ESRI personal geodatabase.
> Any recommendations? Many thanks for any help!!
> Brian C. Bassler
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> Steven Wright <http://www.goodreads.com/author/show/181771.Steven_Wright>
> "I have a map of the United States... Actual size. It says, 'Scale: 1 mile
> = 1 mile.' I spent last summer folding it. I hardly ever unroll it. People
> ask me where I live, and I say, 'E6."
> -- Steven Wright <http://www.goodreads.com/author/show/181771.Steven_Wright
> http://lists.osgeo.org/mailman/listinfo/fdo-users****
> [image: Description: Image removed by sender. Steven Wright]<http://www.goodreads.com/author/show/181771.Steven_Wright>
> -- Steven Wright<http://www.goodreads.com/author/show/181771.Steven_Wright>
[image: Steven Wright]<http://www.goodreads.com/author/show/181771.Steven_Wright>
-- Steven Wright <http://www.goodreads.com/author/show/181771.Steven_Wright>
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20120914/fe299ed1/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20120914/fe299ed1/attachment.jpg>
More information about the fdo-users
