[fdo-users] transaction using fdo-postgis provider
Greg Boone
greg.boone at autodesk.com
Fri Jul 5 08:14:35 PDT 2013
It seems that this scenario requires you to create and maintain a single context or "manager" object as a global owner of the actions you wish to apply. This manager will execute all of your required actions in the combined scenario you quote below. It will own and initialize the FDO Transaction and manage its state. The Transaction will be maintained for as long as the schema modification/data modification routines are running. If a failure occurs and an exception thrown, catch the exception and have the manager cleanup as required.
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of taiyabali
Sent: Friday, July 05, 2013 6:42 AM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] transaction using fdo-postgis provider
HI,
I got it. I have reached halfway. I tried the way jackie suggessted and i found that my insert command is sucessfully rollbacked if any exception occurs. But now my issue is I want to club schema modifications and data modification in one transaction i.e i want to club ApplySchema changes and insert update and delete in one transaction. When i am trying to do the same FdoTransaction fails to rollback.
-taiyabali
View this message in context: http://osgeo-org.1560.x6.nabble.com/transaction-using-fdo-postgis-provider-tp5064065p5064281.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
