[fdo-users] transaction using fdo-postgis provider
Greg Boone greg.boone at autodesk.com
Mon Jul 8 22:07:11 PDT 2013
Ok. Then I go back to Jackie's response... It sounds like he described what you need pretty well.
FdoPtr<FdoITransaction> trans = fdoConn->BeginTransaction();
try
     //Do your changes here
     bool ret = CallMyApplySchema();
     if (ret)
         CallMyInsertFeatures()
     //Commit the transaction when done
     trans->Commit();
catch (FdoException* ex) //Something went wrong
     trans->Rollback();
     ex->Release();
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of taiyabali
Sent: Monday, July 08, 2013 2:20 AM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] transaction using fdo-postgis provider
Hi Greg,
Thanks for replying but can you explain the solution little more. I don't know much about FDO I am very new to this API. Are you saying to make a manager class of our own and manage this transaction manually. If that is what you are suggesting then I don't think its a good solution because transactions in database should be managed by database not on client side.
If your suggestion is something else Then can you please elaborate it a little more. Thanks
taiyabali
View this message in context: http://osgeo-org.1560.x6.nabble.com/transaction-using-fdo-postgis-provider-tp5064065p5064633.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
