[fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)
Traian Stanev
traian.stanev at autodesk.com
Wed May 1 14:40:26 PDT 2013
Hello,
If ogrinfo works fine for that data source, then the FDO provider should also theoretically work. The fact that it fails indicates that it either does not find all the necessary gdal/ogr dlls, or there is some bug in the provider that is specific to FileGDB - I have not heard of anyone else using FileGDB with the provider so far, so it's possible that such a bug exists. You can create a bug report and attach a test file.
Traian
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Matthew N
Sent: Wednesday, May 01, 2013 5:05 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)
I'm testing with Autodesk Map 3D 2014 32-bit.
I added the OSGEO core FDO files as well as OGR provider v3.8.
I added ogr files from Osgeo4W including gdal19.dll (v1.9.2), filegdbapi.dll, ogr_filegdb.dll.
Ogrinfo tests successfully with FileGDB.
Map 3D FDO OGR provider works with SHP and Esri PGDB (mdb file).
Map 3D FDO OGR provider fails with FileGBD data. "Failed to open fdo connection. Connect failed:"
Does FDO OGR provider need to be written to specifically support FileGDB?
Any thought or insights would be helpfull.
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20130501/a199ec23/attachment.html>
More information about the fdo-users
