[fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)
Matthew N xxmatthew at gmail.com
Thu May 2 07:23:30 PDT 2013
test data attached
On Wed, May 1, 2013 at 5:40 PM, Traian Stanev <traian.stanev at autodesk.com>wrote:
> Hello,****
> If ogrinfo works fine for that data source, then the FDO provider should
> also theoretically work. The fact that it fails indicates that it either
> does not find all the necessary gdal/ogr dlls, or there is some bug in the
> provider that is specific to FileGDB – I have not heard of anyone else
> using FileGDB with the provider so far, so it’s possible that such a bug
> exists. You can create a bug report and attach a test file.****
> Traian****
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Matthew N
> *Sent:* Wednesday, May 01, 2013 5:05 PM
> *To:* fdo-users at lists.osgeo.org
> *Subject:* [fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)*
> I'm testing with Autodesk Map 3D 2014 32-bit.****
> I added the OSGEO core FDO files as well as OGR provider v3.8.****
> I added ogr files from Osgeo4W including gdal19.dll (v1.9.2),
> filegdbapi.dll, ogr_filegdb.dll.****
> Ogrinfo tests successfully with FileGDB.****
> Map 3D FDO OGR provider works with SHP and Esri PGDB (mdb file).****
> Map 3D FDO OGR provider fails with FileGBD data. "Failed to open fdo
> connection.  Connect failed:"****
> Does FDO OGR provider need to be written to specifically support FileGDB?*
> Any thought or insights would be helpfull.****
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20130502/736c412e/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20130502/736c412e/attachment-0001.zip>
More information about the fdo-users mailing list
