[fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)
Brad Nesom
kidsmake6 at msn.com
Thu May 2 10:59:12 PDT 2013
there is a limitation on the fgdb version in the api.
unless it has changed recently it is only supported on 10.0 fgdb.
On Thu, May 2, 2013 at 9:23 AM, Matthew N <xxmatthew at gmail.com> wrote:
> test data attached
> On Wed, May 1, 2013 at 5:40 PM, Traian Stanev <traian.stanev at autodesk.com>
> wrote:
>> Hello,
>> If ogrinfo works fine for that data source, then the FDO provider should
>> also theoretically work. The fact that it fails indicates that it either
>> does not find all the necessary gdal/ogr dlls, or there is some bug in the
>> provider that is specific to FileGDB - I have not heard of anyone else using
>> FileGDB with the provider so far, so it's possible that such a bug exists.
>> You can create a bug report and attach a test file.
>> Traian
>> From: fdo-users-bounces at lists.osgeo.org
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Matthew N
>> Sent: Wednesday, May 01, 2013 5:05 PM
>> To: fdo-users at lists.osgeo.org
>> Subject: [fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)
>> I'm testing with Autodesk Map 3D 2014 32-bit.
>> I added the OSGEO core FDO files as well as OGR provider v3.8.
>> I added ogr files from Osgeo4W including gdal19.dll (v1.9.2),
>> filegdbapi.dll, ogr_filegdb.dll.
>> Ogrinfo tests successfully with FileGDB.
>> Map 3D FDO OGR provider works with SHP and Esri PGDB (mdb file).
>> Map 3D FDO OGR provider fails with FileGBD data. "Failed to open fdo
>> connection. Connect failed:"
>> Does FDO OGR provider need to be written to specifically support FileGDB?
>> Any thought or insights would be helpfull.
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
"I have a map of the United States... Actual size. It says, 'Scale: 1
mile = 1 mile.' I spent last summer folding it. I hardly ever unroll
it. People ask me where I live, and I say, 'E6."
-- Steven Wright
More information about the fdo-users
