[fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)
Heddo Klandermans
h.klandermans at hawarIT.com
Fri May 3 00:59:48 PDT 2013
Hello,
As for 64-bit OGR-provider (tested on AutoCAD Map 3D 2013): it works
fine for pGDB (.mdb) but also has similar problems with fGDB (.gdb).
Simple work around, though not satisfactory of course, is to ask
suppliers to transfer data (e.g. using ESRI's distributed
geodatabase-command) to pGDB.
H.D. (Heddo) Klandermans
Senior Consultant
Hawar Information Technology bv
Oude Koemarkt 59b, 8601EJ Sneek
Tel.: +31 515 570333
Mob.: +31 6 15373947
E-mail: h.klandermans at HawarIT.com
Op 2-5-2013 19:59, Brad Nesom schreef:
> there is a limitation on the fgdb version in the api.
> unless it has changed recently it is only supported on 10.0 fgdb.
> On Thu, May 2, 2013 at 9:23 AM, Matthew N <xxmatthew at gmail.com> wrote:
>> test data attached
>> On Wed, May 1, 2013 at 5:40 PM, Traian Stanev <traian.stanev at autodesk.com>
>> wrote:
>>> Hello,
>>> If ogrinfo works fine for that data source, then the FDO provider should
>>> also theoretically work. The fact that it fails indicates that it either
>>> does not find all the necessary gdal/ogr dlls, or there is some bug in the
>>> provider that is specific to FileGDB - I have not heard of anyone else using
>>> FileGDB with the provider so far, so it's possible that such a bug exists.
>>> You can create a bug report and attach a test file.
>>> Traian
>>> From: fdo-users-bounces at lists.osgeo.org
>>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Matthew N
>>> Sent: Wednesday, May 01, 2013 5:05 PM
>>> To: fdo-users at lists.osgeo.org
>>> Subject: [fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)
>>> I'm testing with Autodesk Map 3D 2014 32-bit.
>>> I added the OSGEO core FDO files as well as OGR provider v3.8.
>>> I added ogr files from Osgeo4W including gdal19.dll (v1.9.2),
>>> filegdbapi.dll, ogr_filegdb.dll.
>>> Ogrinfo tests successfully with FileGDB.
>>> Map 3D FDO OGR provider works with SHP and Esri PGDB (mdb file).
>>> Map 3D FDO OGR provider fails with FileGBD data. "Failed to open fdo
>>> connection. Connect failed:"
>>> Does FDO OGR provider need to be written to specifically support FileGDB?
>>> Any thought or insights would be helpfull.
>>> fdo-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
