[fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)
    Matthew N
    xxmatthew at gmail.com
    Fri May  3 03:36:45 PDT 2013
The workaround is to use ogr2ogr or Quantum GIS to convert the fileGDB data
to Shp/sdf/sqlite.  It works in both 32bit and 64bit Windows.
On 2013-05-03 5:01 AM, "Heddo Klandermans" <h.klandermans at hawarit.com>
wrote:
> Hello,
> As for 64-bit OGR-provider (tested on AutoCAD Map 3D 2013): it works fine
> for pGDB (.mdb) but also has similar problems with fGDB (.gdb).
> Simple work around, though not satisfactory of course, is to ask suppliers
> to transfer data (e.g. using ESRI's distributed geodatabase-command) to
> pGDB.
> H.D. (Heddo) Klandermans
> Senior Consultant
>  Hawar Information Technology bv
> Oude Koemarkt 59b, 8601EJ Sneek
> Tel.: +31 515 570333
> Mob.: +31 6 15373947
> E-mail: h.klandermans at HawarIT.com
> Op 2-5-2013 19:59, Brad Nesom schreef:
>> there is a limitation on the fgdb version in the api.
>> unless it has changed recently it is only supported on 10.0 fgdb.
>> On Thu, May 2, 2013 at 9:23 AM, Matthew N <xxmatthew at gmail.com> wrote:
>>> test data attached
>>> On Wed, May 1, 2013 at 5:40 PM, Traian Stanev <
>>> traian.stanev at autodesk.com>
>>> wrote:
>>>> Hello,
>>>> If ogrinfo works fine for that data source, then the FDO provider should
>>>> also theoretically work. The fact that it fails indicates that it either
>>>> does not find all the necessary gdal/ogr dlls, or there is some bug in
>>>> the
>>>> provider that is specific to FileGDB - I have not heard of anyone else
>>>> using
>>>> FileGDB with the provider so far, so it's possible that such a bug
>>>> exists.
>>>> You can create a bug report and attach a test file.
>>>> Traian
>>>> From: fdo-users-bounces at lists.osgeo.**org<fdo-users-bounces at lists.osgeo.org>
>>>> [mailto:fdo-users-bounces@**lists.osgeo.org<fdo-users-bounces at lists.osgeo.org>]
>>>> On Behalf Of Matthew N
>>>> Sent: Wednesday, May 01, 2013 5:05 PM
>>>> To: fdo-users at lists.osgeo.org
>>>> Subject: [fdo-users] fileGDB support in FDO OGR 3.8 32-bit (and 64-bit)
>>>> I'm testing with Autodesk Map 3D 2014 32-bit.
>>>> I added the OSGEO core FDO files as well as OGR provider v3.8.
>>>> I added ogr files from Osgeo4W including gdal19.dll (v1.9.2),
>>>> filegdbapi.dll, ogr_filegdb.dll.
>>>> Ogrinfo tests successfully with FileGDB.
>>>> Map 3D FDO OGR provider works with SHP and Esri PGDB (mdb file).
>>>> Map 3D FDO OGR provider fails with FileGBD data. "Failed to open fdo
>>>> connection.  Connect failed:"
>>>> Does FDO OGR provider need to be written to specifically support
>>>> FileGDB?
>>>> Any thought or insights would be helpfull.
>>>> ______________________________**_________________
>>>> fdo-users mailing list
>>>> http://lists.osgeo.org/**mailman/listinfo/fdo-users<http://lists.osgeo.org/mailman/listinfo/fdo-users>
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20130503/8cbf450d/attachment.html>
More information about the fdo-users
