[fdo-users] Problems with AutoCAD Map on PostGIS
Dietmar Fleischhauer (WhereGroup)
d.fleischhauer at wheregroup.com
Tue Sep 17 03:48:53 PDT 2013
one of our customers has severe problems with AutoCAD Map (2013 and 2014
on Windows 7) on a PostGIS 2.0 database (PostgreSQL 9.1 on Ubuntu 12.04)
via FDO.
Different FDO dll versions between 3.7.x and the latest 3.8.0 have been
tested (bundled with AutoCAD Map as well as downloaded from OSGeo).
The Problem: connections seem to be lost by the FDO driver. So far all
errors appear analogous to this PG log example (identical timestamp
omitted, statements shortened; first appearance of the error in this
session):
LOG: duration: 4.133 ms parse fdo18: SELECT tc.conname [...]
LOG: duration: 0.574 ms parse <unnamed>: DECLARE fdo18 CURSOR FOR
LOG: duration: 0.687 ms bind <unnamed>: DECLARE fdo18 CURSOR FOR
LOG: duration: 0.223 ms execute <unnamed>: DECLARE fdo18 CURSOR FOR
LOG: duration: 0.117 ms statement: FETCH 512 FROM fdo18
LOG: duration: 1.071 ms statement: FETCH 512 FROM fdo19
LOG: duration: 0.483 ms statement: FETCH 512 FROM fdo20
LOG: duration: 0.331 ms statement: FETCH 512 FROM fdo21
LOG: duration: 0.025 ms statement: DEALLOCATE fdo21
LOG: duration: 0.023 ms statement: DEALLOCATE fdo20
LOG: duration: 2.022 ms statement: FETCH 512 FROM fdo13
LOG: unexpected EOF on client connection
LOG: connection received: host=10.0.10.22 port=61421
LOG: connection authorized: user=autocad database=foo
ERROR: prepared statement "fdo19" does not exist
STATEMENT: DEALLOCATE fdo19
ERROR: prepared statement "fdo18" does not exist
STATEMENT: DEALLOCATE fdo18
Client logging isn't very verbose and doesn't show anything beyond the
information above.
This kind of error could be reproduced (on a random base) in a different
location and environment (PG on Windows Server 2008 R2, same PostGIS and
PG versions, different AutoCAD Map PCs). Both settings are LAN based
without any routing, so we assume it's not a network problem (at least
below the application layer). Also server memory shouldn't be an issue,
the Ubuntu production server has 10G RAM with PG shared_buffers 2560MB,
while the errors occur with single connection
Those errors happen over and over unpredictably. In one case directly
when reading the schema after connecting, next time after having loaded
a bunch of layers correctly. In rare cases everything works. (N.B.: a
UMN based web application using the same database works without error;
and was deactivated during Autodesk testing).
Any hints would be very appreciated, thanks!
Regards,
Dietmar
Type: application/pkcs7-signature
Desc: S/MIME Kryptografische Unterschrift
URL: <http://lists.osgeo.org/pipermail/fdo-users/attachments/20130917/75d8d88f/attachment.bin>
More information about the fdo-users
