[fdo-users] Can't select features using SQL Server data connection
Martin Morrison
martin.morrison at edsi.com
Tue Jun 26 05:22:44 PDT 2018
Do you have a primary key set?
Martin Morrison
Infrastructure Application Engineer/Systems Analyst
Engineering Design Systems, Inc.
540.345.1410
-----Original Message-----
From: fdo-users [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Elad
Sent: Tuesday, June 26, 2018 3:16 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Can't select features using SQL Server data connection
Hi. I'm new to MapGuide and Maestro but I am expirienced programmer.
I have shape files and I have also imported them into MS SQL Server using shape2sql.
When I create a data connection directly to the shape files, and then create a layer for some feature, I am able to select features using the select tool on the map.
But, when I create the same layer using the SQL Server spatial feature source, the features are shown but are not selectable. When trying to select, it looks like it is processing (the red rectangle hangs for a while on the screen) but after few seconds, it says "0 features selected" and the features are not highlighted as using the shape file directly.
What I've tried so far: I susspected that when using the shape files directly, Maestro recognized the other files such as the .prj files with the coordinate system so in the data connection, I have set the coordinate system manualy to what ever it is in the prj file. It didn't help.
I have other issues such as slowness compared to working with the shape files directly.
I realize the shape2sql is outdated and perhaps misimported the data into the database, but it does show correctly on the map with all the other feature data.
Interstingly, when I set the tooltip to "TYPE" for example which is one of the feature data fields, it is shown! I can't select features even using the single feature selection.
Please help.
by the way, is there a forum for newbies?
Thanks.
Sent from: http://osgeo-org.1560.x6.nabble.com/FDO-Users-f3898664.html
fdo-users mailing list
https://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
