[fdo-dev] bulk copy
Haris Kurtagic
haris at sl-king.com
Fri Oct 20 13:25:40 EDT 2006
I thought more like question: How should well written open source FDO
provider expose functionality so it will be accepted by FDO client's
which are open or not open source.
Haris
From: Greg Boone [mailto:greg.boone at autodesk.com]
Sent: Friday, October 20, 2006 7:16 PM
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] bulk copy
This sounds like a Autodesk Map support question rather than an FDO Open
Source question. Bulk Copy is not a part of Open Source.
Greg
Sent: Thursday, October 19, 2006 7:21 PM
Subject: [fdo-dev] bulk copy
I can successfully use King.Oracle provider to query and edit data
inside Autodesk MAP.
When I try MAP command for Bulk Copy, I can't use King.Oracle connection
beacuse It doesn't appear in list box (Data Source - Connection Name).
I suppose provider needs to satisfy some capabilities
(FdoCommandType_CreateDataStore, FdoCommandType_ApplySchema,...) ?
If someone can point me into right direction ?
I couldn't find anything in docs.
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20061020/2cd0395a/attachment.html
More information about the Fdo_dev
