[fdo-dev] bulk copy
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 20 13:44:22 EDT 2006
> *From:* Greg Boone [mailto:greg.boone at autodesk.com]
> *Sent:* Friday, October 20, 2006 7:16 PM
> *To:* dev at fdo.osgeo.org
> *Subject:* RE: [fdo-dev] bulk copy
> This sounds like a Autodesk Map support question rather than an FDO Open
> Source question. Bulk Copy is not a part of Open Source.
Greg,
Does this mean that bulk copy in Map is done by a means other than FDO? Or
do you mean that bulk copy hasn't been a focus of the open source FDO
work since it wouldn't be used by mapguide? Or...?
I, for one, do want to be able to deliver useful FDO providers for use in
Map based on the open source FDO core. So I'm interested in what limitations
I might encounter in doing so.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the Fdo_dev
