[fdo-dev] Connection string
Robert Fortin
robert.fortin at autodesk.com
Thu Sep 7 14:47:22 EDT 2006
Gabriel,
you can always get the list of valid connection parameters for any FDO
provider by looking at the
FdoIConnection->GetConnectionInfo->GetConnectionProperties.
You can also set the connection parameter values this way instead of
using the SetConnectionString. It is more convenient with UI.
RF
_____
Sent: Thursday, September 07, 2006 2:37 PM
To: dev at fdo.osgeo.org
Cc: Gabriel Ajayi
Subject: RE: [fdo-dev] Connection string
You should try:
connection->SetConnectionString(L" DefaultFileLocation=test.shp")
You can have a look at the SHP unit tests.
_____
Sent: Thursday, September 07, 2006 12:49 PM
Subject: [fdo-dev] Connection string
What is the format of the connection string for a shape file?
connection->SetConnectionString(L"SHPFile=test.shp") doesn't seem to
work.
URL: http://lists.osgeo.org/pipermail/fdo_dev/attachments/20060907/d9c2f7e9/attachment.html
More information about the Fdo_dev
