[Fdo_dev] About RDBI's get_gen_id() function
Dan Stoica
dan.stoica at autodesk.com
Wed Jan 10 14:18:34 EST 2007
Therefore, Mateusz, the answer to your question is simple: YOU :-)
Cheers,
Dan.
-----Original Message-----
[mailto:fdo_dev-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Wednesday, January 10, 2007 12:43 PM
To: Badreddine Karoui; fdo_dev
Subject: RE: [Fdo_dev] About RDBI's get_gen_id() function
Any changes would have to go into the PostGIS branch only. Once the
change has been reviewed it can be integrated into the GenericRDBMS
trunk. This change should not be integrated into the 3.2.x branch.
[mailto:fdo_dev-bounces at lists.osgeo.org] On Behalf Of Badreddine Karoui
Sent: Wednesday, January 10, 2007 12:32 PM
To: fdo_dev
Go ahead. But can you hold off changing subversion until tomorrow?
Badreddine
[mailto:fdo_dev-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Wednesday, January 10, 2007 12:17 PM
To: fdo_dev
Subject: Re: [Fdo_dev] About RDBI's get_gen_id() function
Badreddine Karoui wrote:
> Hi,
> The GDBI/RDBI interface is not cast in stone. Option 1 seems the
> reasonable solution to me.
> MySql driver just have to be fixed up in this
> case and no need for the kludge of option 2.
OK, so I'm waiting for answer on my question who is going to fix it.
I can do it too.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
Fdo_dev mailing list
Fdo_dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo_dev
More information about the Fdo_dev
