[fdo][FDO139][Modified] Fix unit tests on Linux after Update Constraints submission ...
Dan Stoica dan.stoica at autodesk.com
Mon Aug 28 17:54:43 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO139
Type:
Defect
Artifact ID:
FDO139 (Fix unit tests on Linux after Update Constraints submission (FDO136))
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO139
Modified
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp?view=diff&rev=170&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r1=169&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r2=170
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp?view=diff&rev=170&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp&r1=169&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp&r2=170
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
