[fdo][FDO140][New] tempnam security risk in FdoCommonFile.cpp
Mateusz Loskot mateusz at loskot.net
Mon Aug 28 18:41:42 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO140
Type
 Defect
Artifact ID
 FDO140 (tempnam security risk in FdoCommonFile.cpp)
Reported by
 Mateusz Loskot
 mloskot (mateusz at loskot.net)
New artifact details:
- Defect Severity set to new value
  Medium
- Summary set to new value
- Platform set to new value
  All
- Artifact created
- Subcomponent set to new value
  UTILITIES
- Artifact Status set to new value
  Unconfirmed
- Operating system set to new value
  Linux
- Component set to new value
- Description set to new value
  In file fdocore/trunk/Utilities/Common/Src/FdoCommonFile.cpp,
line 837, tempnam() function is used.
This function introduces well-known security risk and it's recommended to use mkstemp() instead.
For more details, see security considerations of tempnam manual page.
Here is also some discussion of tempnam() usage in cstring utility, but Eric Raymond gives generally applicable explanation of the issue:
http://www.securityfocus.com/bid/9391/info
AFAIK, it applies to systems with symbolic links support.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
