[fdo][FDO143][New] Fixed defect 784301 SHP: Describe Schema fails on shp files ...
Romica Dascalescu romica.dascalescu at autodesk.com
Tue Aug 29 11:56:27 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO143
Type
 Defect
Artifact ID
 FDO143 (Fixed defect 784301 SHP: Describe Schema fails on shp files with same named projection but different details of the projection)
Reported by
 Romica Dascalescu
 romicadascalescu (romica.dascalescu at autodesk.com)
New artifact details:
- Defect Severity set to new value
  Medium
- Summary set to new value
- Artifact created
- Description set to new value
Generated a new spatial context name, based on the duplicate name and a number.
Added a new test.
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
