[fdo][FDO143][User] Fixed defect 784301 SHP: Describe Schema fails on shp files ...
Romica Dascalescu
romica.dascalescu at autodesk.com
Tue Aug 29 11:56:45 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO143
Type:
Defect
Artifact ID:
FDO143 (Fixed defect 784301 SHP: Describe Schema fails on shp files with same named projection but different details of the projection)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Assigned to:
romicadascalescu
-- New value added to attribute Reviewer:
danstoica
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
