[fdo][FDO346][New] MySQL - Cannot query features from MySQL with a column type ...
Barbara Zoladek
barbara.zoladek at autodesk.com
Fri Dec 15 16:57:53 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO346
Type
Defect
Artifact ID
FDO346 (MySQL - Cannot query features from MySQL with a column type "LONGTEXT")
Reported by
Barbara Zoladek
barbarazoladek (barbara.zoladek at autodesk.com)
New artifact details:
- Defect Severity set to new value
Medium
- Summary set to new value
- Artifact created
- Description set to new value
MySQL - RevEng: Cannot query features from MySQL with a column type "LONGTEXT"
Create a MySQL database with the following definition:
CREATE DATABASE MySQL_ModForeign;
CREATE TABLE MySQL_ModForeign.Point
(GEOMETRY POINT,
ENTITYID INT AUTO_INCREMENT PRIMARY KEY,
FSTEXTCONTENT LONGTEXT)
ENGINE = MYISAM;
ALTER TABLE MySQL_ModForeign.Point AUTO_INCREMENT = 201;
populate the table with at least one feature. The attached file can be used to load data with the following command at the MySQL prompt:
LOAD DATA INFILE '<<path>>/POINT.out'
INTO TABLE MySQL_ModForeign.Point
FIELDS TERMINATED BY ','
LINES TERMINATED BY '\n';
The describe schema returns the FSTEXTCONTENT type as a FdoDataType_String but the length seems excessively long:
INFO: SchemaDefinition.point Properties: ():
Qualified Name: Fdomysql_modforeign:point.FSTEXTCONTENT
Description:
DataProperty Type: FdoDataType_String
Read Only: False
Nullable: True
Default Value:
Precision: 0
Scale: 0
Length: 2147483647
When we query the feature we get the following exception:
FdoCommandException(): RDBMS:
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
