[fdo][FDO347][New] ArcSDE: Improve schema performance
Pierre Dalcourt
pierre.dalcourt at autodesk.com
Fri Dec 15 17:23:46 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO347
Type
Enhancement
Artifact ID
FDO347 (ArcSDE: Improve schema performance)
Reported by
Pierre Dalcourt
pierredalcourt (pierre.dalcourt at autodesk.com)
New artifact details:
- Summary set to new value
- Artifact Status set to new value
New
- Description set to new value
Improved DescribeSchema performance in ArcSDE.
1) Cache SE_REGINFO array; re-use it instead of refetching it.
2) Cache SE_METADATAINFO array; re-use it instead of refetching it.
Also, fetch it all at once instead of one request per table; this
is a higher upfront cost but cheaper in the long run since its
only one fetch to the database instead of many.
3) Only read fdo-specific schema metadata in debug mode. This is consistent
with the fact that ApplySchema is only supported in debug mode, and ApplySchema
is the only command that will generate fdo-specific schema metadata in the
database.
4) If the client hasn't done an explicit DescribeSchema, and we require schema
information internally for 1 class only, load only the schema information for
that class. Cache it in case its requested multiple times. Augment the cache
intelligently if more classes are requested on a class-by-class basis.
Performance changes were measured. The configuration was of using a T040p
laptop client (release mode) in Ottawa against an ArcSDE 9.1 oracle database
(with 122 arcsde tables) in Florida.
The measure improvements are as follows (averaged results of 2 runs):
A) DescribeSchema (on ~125 tables): 31.1% improvement (82.6 secs --> 56.9 secs)
B) Select and read 1088 features twice, calling all Get methods: 87.8%
improvement.= (90.3 secs --> 11.05 secs)
C) Non-measured improvements in locking and long transaction commands, due to
Optimization #1 above.
Also fixed some typos.
TESTING PERFORMED:
Ran a variety of unit tests with no new errors.
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
