[fdo][FDO348][New] Constraints parser does not understand 'YYYY-MM-DD-HH24-MI-S...
Dan Stoica dan.stoica at autodesk.com
Mon Dec 18 09:35:20 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO348
Type
 Defect
Artifact ID
 FDO348 (Constraints parser does not understand 'YYYY-MM-DD-HH24-MI-SS' syntax)
Reported by
 Dan Stoica
 danstoica (dan.stoica at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Summary set to new value
- Description set to new value
  Currently the \Utililities\Common\Src\Parse\Lex.cpp understands only 'YYYY-MM-DD H24:MI:SS' syntax for dates. It needs enhancement to handle other datetime formats like 'YYYY-MM-DD-HH24-MI-SS'.
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
