[fdo][FDO348][User] Constraints parser does not understand 'YYYY-MM-DD-HH24-MI-S...
Dan Stoica dan.stoica at autodesk.com
Mon Dec 18 09:35:31 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO348
Type:
Defect
Artifact ID:
FDO348 (Constraints parser does not understand 'YYYY-MM-DD-HH24-MI-SS' syntax)
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Assigned to:
danstoica
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
