[fdo][FDO348][Modified] Constraints parser does not understand 'YYYY-MM-DD-HH24-MI-S...
Dan Stoica
dan.stoica at autodesk.com
Mon Dec 18 09:36:22 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO348
Type:
Defect
Artifact ID:
FDO348 (Constraints parser does not understand 'YYYY-MM-DD-HH24-MI-SS' syntax)
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO348
Modified
File: branches/3.2.x/Utilities/Common/Src/Parse/Lex.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/Common/Src/Parse/Lex.cpp?view=diff&rev=602&p1=branches/3.2.x/Utilities/Common/Src/Parse/Lex.cpp&r1=601&p2=branches/3.2.x/Utilities/Common/Src/Parse/Lex.cpp&r2=602
File: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Table.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Table.h?view=diff&rev=602&p1=branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Table.h&r1=601&p2=branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Table.h&r2=602
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp?view=diff&rev=602&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp&r1=601&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp&r2=602
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
