[fdo][FDO352][New] SDF defect fixes
Badreddine Karoui
badreddine.karoui at autodesk.com
Tue Dec 19 15:44:28 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO352
Type
Defect
Artifact ID
FDO352 (SDF defect fixes)
Reported by
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Summary set to new value
SDF defect fixes
- Description set to new value
This change fixes 2 issues one related to the scrallable reader getting its context ovewritten by a feature reader. This happen if the 2 readers are open an being used against the same class/table.
The second issue happen when a huge amounts of edits happen to the RTree which may trigger alot of deletes and addition of new nodes. The id of the new nodes may re-use existing ids and overwrite existing nodes.
- Submission Reviewed set to new value
Yes
- Defect Severity set to new value
Medium
- Artifact created
- Artifact Status set to new value
New
- Component set to new value
SDF
- Subcomponent set to new value
FEATURE COMMANDS
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
