[fdo][FDO353][New] ApplySchema tries to add unique constraints on identity prop...
Brent Robinson
brent.robinson at autodesk.com
Tue Dec 19 17:37:05 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO353
Type
Defect
Artifact ID
FDO353 (ApplySchema tries to add unique constraints on identity properties.)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
- Perform an FdoFeatureSchemaCollection::ReadXml() on the attached XML file.
- Perform an ApplySchema, using the 1st feature schema from the above collection
- Defect Severity set to new value
High
- Target milestone set to new value
3.2.1
- Description set to new value
A Feature Schema class can have a unique constraint that exactly contains the class identity properties. If the feature schema is passed to ApplySchema then ApplySchema will try to create the unique constraint. However, some RDBMS's do not allow a unique constraint to have the exact same columns as the primary key for the constraint's table. The RDBMS providers map identity properties onto primary key columns.
- Artifact Status set to new value
New
- Component set to new value
RDBMS
- Platform set to new value
All
- Priority set to new value
P2
- Artifact created
- Version set to new value
V2
- Operating system set to new value
All
- Summary set to new value
- Subcomponent set to new value
SCHEMA
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
