[fdo][FDO99][Modified] Fixed SHP unit test failures on Linux (non_ascii_class_name*...
Romica Dascalescu
romica.dascalescu at autodesk.com
Wed Jul 26 16:59:49 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO99
Type:
Task
Artifact ID:
FDO99 (Fixed SHP unit test failures on Linux (non_ascii_class_name*))
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
-- Testing Notes set to new value:
Old value:
Rebuild Granite on Fedora Core3 & Fedora Core4.
Run the unit testes from command line and from crontab.
New value:
Run the SHP unit testes from command line and from crontab.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
