[fdo][FDO100][New] Defect 750920: FdoXmlFeatureSerialize.XMLSerialize() causes ...
Brent Robinson brent.robinson at autodesk.com
Thu Jul 27 10:00:41 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO100
Type
 Defect
Artifact ID
 FDO100 (Defect 750920: FdoXmlFeatureSerialize.XMLSerialize() causes Bad parameter to method exception)
Reported by
 Brent Robinson
 brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Resolution Description set to new value
  - Modified the FdoXmlFeatureWriter constructor that takes an FdoXmlWriter. It now wraps an FdoXmlFeaturePropertyWriter around the FdoXmlWriter. This resolves the "bad parameter" error.
- While testing the fix, found that base property values are not written out when features are serialized. Modified FdoXmlFeatureSerializer to write out values for base properties for each feature.
- Another problem found while testing was that, when multiple features are serialized to XML, object and association property values are only written for the first feature. FdoXmlFeatureWriter was changed to reset the caching state after an object or association property is written.
- Steps to Reproduce set to new value
  1/ Create, setup, and Execute the Select Command to get a Feature Reader.
2/ Create the FdoXmlWriter  and FdoXmlFeatureWriter with the Fd0XmlWriter
FdoXmlWriter = FdoXmlWriter.Create( sFileName, True, FdoXmlWriter.LineFormat_Indent, 0 )
xmlFeatureWriter = FdoXmlFeatureWriter.Create( FdoXmlWriter, None )
3/ Create the FdoXmlFeatureFlags
xmlFeatureFlags = FdoXmlFeatureFlags.Create( None, FdoXmlFlags.ErrorLevel_Normal, True, FdoXmlFeatureFlags.ConflictOption_Add )
4/ Serialize the features to XML using the FdoXmlFeeatureSerializer.XmlSerialize()
FdoXmlFeatureSerializer.XmlSerialize( featureReader, xmlFeatureWriter, xmlFeatureFlags )
The last call to XmlSerialize() causes "Bad parameter to method"
- Developer Notes set to new value
  See Resolution Description.
- Subcomponent set to new value
  XML IN/OUT
- Component set to new value
- Testing Notes set to new value
  A case was added to GmlWriteTest to exercise the case where an FdoXmlFeatureWriter is created around an FdoXmlWriter
- Target milestone set to new value
  3.2.0
- Defect Severity set to new value
  High
- Artifact created
- Operating system set to new value
  All
- Platform set to new value
  All
- Description set to new value
  FdoXmlFeatureSerialize.XMLSerialize() causes Bad parameter to method exception, when created with an FdoXmlWriter.
- Priority set to new value
  P2
- Summary set to new value
- Artifact Status set to new value
  New
- Build set to new value
  G012
- Version set to new value
  V1
Reason:
Fix an assigned Granite defect
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
