[fdo][FDO262][New] FDO: Fix 837057 Oracle geometry performance
    Gavin Cramer
    gavin.cramer at autodesk.com
    Mon Nov  6 10:37:00 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO262
Type
 Defect
Artifact ID
 FDO262 (FDO: Fix 837057 Oracle geometry performance)
Reported by
 Gavin Cramer
 gavincramer (gavin.cramer at autodesk.com)
New artifact details:
- Summary set to new value
- Artifact Status set to new value
  New
- Description set to new value
  This carries out changes in FdoGeometry to complement those done in Oracle
Provider to cut overhead during geometry handling.  Internal changes were done
to reduce heap activity by:
 - doing a bit more object pooling
 - using some newer constructors that don't require per-position object creation
This makes Oracle Provider about 5% faster for feature retrieval.  Other providers that use FdoGeometry may see a bigger or smaller difference, depending on their datastore's native overhead.
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
