[fdo][FDO262][Modified] FDO: Fix 837057 Oracle geometry performance
Gavin Cramer
gavin.cramer at autodesk.com
Mon Nov 6 10:54:14 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO262
Type:
Defect
Artifact ID:
FDO262 (FDO: Fix 837057 Oracle geometry performance)
Modified by:
Gavin Cramer
gavincramer (gavin.cramer at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO262
Modified
File: branches/3.2.x/Fdo/UnitTest/UnitTest.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/UnitTest/UnitTest.vcproj?view=diff&rev=491&p1=branches/3.2.x/Fdo/UnitTest/UnitTest.vcproj&r1=490&p2=branches/3.2.x/Fdo/UnitTest/UnitTest.vcproj&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Common.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Common.vcproj?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Common.vcproj&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Common.vcproj&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Fdo.vcproj&r2=491
File: branches/3.2.x/Fdo/Unmanaged/FileToHdr.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/FileToHdr.vcproj?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/FileToHdr.vcproj&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/FileToHdr.vcproj&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Geometry.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Geometry.vcproj?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Geometry.vcproj&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Geometry.vcproj&r2=491
File: branches/3.2.x/Fdo/Unmanaged/McToMsf.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/McToMsf.vcproj?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/McToMsf.vcproj&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/McToMsf.vcproj&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Message.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Message.vcproj?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Message.vcproj&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Message.vcproj&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Nls.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Nls.vcproj?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Nls.vcproj&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Nls.vcproj&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Spatial.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Spatial.vcproj?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Spatial.vcproj&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Spatial.vcproj&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory.cpp?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory.cpp&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory.cpp&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory2.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory2.h?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory2.h&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory2.h&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.cpp?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.cpp&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.cpp&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.h?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.h&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.h&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h&r2=491
File: branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp?view=diff&rev=491&p1=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp&r1=490&p2=branches/3.2.x/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp&r2=491
File: branches/3.2.x/Utilities/Common/FdoCommon.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/Common/FdoCommon.vcproj?view=diff&rev=491&p1=branches/3.2.x/Utilities/Common/FdoCommon.vcproj&r1=490&p2=branches/3.2.x/Utilities/Common/FdoCommon.vcproj&r2=491
File: branches/3.2.x/Utilities/SchemaMgr/LogicalPhysical.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/LogicalPhysical.vcproj?view=diff&rev=491&p1=branches/3.2.x/Utilities/SchemaMgr/LogicalPhysical.vcproj&r1=490&p2=branches/3.2.x/Utilities/SchemaMgr/LogicalPhysical.vcproj&r2=491
File: branches/3.2.x/Utilities/SchemaMgr/Overrides.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Overrides.vcproj?view=diff&rev=491&p1=branches/3.2.x/Utilities/SchemaMgr/Overrides.vcproj&r1=490&p2=branches/3.2.x/Utilities/SchemaMgr/Overrides.vcproj&r2=491
File: branches/3.2.x/Utilities/SchemaMgr/Physical.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Physical.vcproj?view=diff&rev=491&p1=branches/3.2.x/Utilities/SchemaMgr/Physical.vcproj&r1=490&p2=branches/3.2.x/Utilities/SchemaMgr/Physical.vcproj&r2=491
File: branches/3.2.x/Utilities/SchemaMgr/SchemaMgr.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/SchemaMgr.vcproj?view=diff&rev=491&p1=branches/3.2.x/Utilities/SchemaMgr/SchemaMgr.vcproj&r1=490&p2=branches/3.2.x/Utilities/SchemaMgr/SchemaMgr.vcproj&r2=491
File: branches/3.2.x/Utilities/SchemaMgr/SmMessage.vcproj https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/SmMessage.vcproj?view=diff&rev=491&p1=branches/3.2.x/Utilities/SchemaMgr/SmMessage.vcproj&r1=490&p2=branches/3.2.x/Utilities/SchemaMgr/SmMessage.vcproj&r2=491
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
