[fdo][FDO277][New] The SDF spatial query may return the wrong number of objects...
    Badreddine Karoui
    badreddine.karoui at autodesk.com
    Thu Nov  9 10:53:04 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO277
Type
 Defect
Artifact ID
 FDO277 (The SDF spatial query may return the wrong number of objects in case of multiple connections updates)
Reported by
 Badreddine Karoui
 badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Priority set to new value
  P2
- Component set to new value
  SDF
- Artifact Status set to new value
  New
- Defect Severity set to new value
  Medium
- Description set to new value
  The issue happens if 2 or more connections are created, then those connections are used to write few features each.
After writting the data, the first connection is used to make a spatial query. The returned result may be wrong and that depend if the the last write changed the internal RTree root node.
- Artifact created
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
