[fdo][FDO281][New] SDF:Constraints creating a Value Range constraint crashes FD...
Jack Lee
jack.lee at autodesk.com
Fri Nov 10 14:01:52 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO281
Type
Defect
Artifact ID
FDO281 (SDF:Constraints creating a Value Range constraint crashes FDO)
Reported by
Jack Lee
jacklee (jack.lee at autodesk.com)
New artifact details:
- Description set to new value
- Summary set to new value
- Artifact created
- Artifact Status set to new value
New
- Steps to Reproduce set to new value
Create a feature class
Add a FdodataProperty with a FdoPropertyValueConstraintRange(min or max but not both)
Execute the ApplySchemaCommand
RESULTS: get an unhandled exception
EXPECTED BEHAVIOR: constraint is properly created without error.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
