[fdo][FDO281][Modified] SDF:Constraints creating a Value Range constraint crashes FD...
Jack Lee
jack.lee at autodesk.com
Fri Nov 10 15:06:42 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO281
Type:
Defect
Artifact ID:
FDO281 (SDF:Constraints creating a Value Range constraint crashes FDO)
Modified by:
Jack Lee
jacklee (jack.lee at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO281 - Handle the case where the min or max range constraints is not set
Modified
File: branches/3.2.x/Utilities/Common/Src/FdoCommonSchemaUtil.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/Common/Src/FdoCommonSchemaUtil.cpp?view=diff&rev=502&p1=branches/3.2.x/Utilities/Common/Src/FdoCommonSchemaUtil.cpp&r1=501&p2=branches/3.2.x/Utilities/Common/Src/FdoCommonSchemaUtil.cpp&r2=502
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
