[fdo][FDO281][Modified] SDF:Constraints creating a Value Range constraint crashes FD...
Jack Lee jack.lee at autodesk.com
Fri Nov 10 15:13:52 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO281
Type:
Defect
Artifact ID:
FDO281 (SDF:Constraints creating a Value Range constraint crashes FDO)
Modified by:
Jack Lee
jacklee (jack.lee at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO281 - Merge from branch 3.2.x
Handle the case where the min or max range constraints is not set
Modified
File: trunk/Utilities/Common/Src/FdoCommonSchemaUtil.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/Common/Src/FdoCommonSchemaUtil.cpp?view=diff&rev=503&p1=trunk/Utilities/Common/Src/FdoCommonSchemaUtil.cpp&r1=502&p2=trunk/Utilities/Common/Src/FdoCommonSchemaUtil.cpp&r2=503
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
