[fdo][FDO281][Modified] SDF:Constraints creating a Value Range constraint crashes FD...
Jack Lee
jack.lee at autodesk.com
Fri Nov 10 15:33:19 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO281
Type:
Defect
Artifact ID:
FDO281 (SDF:Constraints creating a Value Range constraint crashes FDO)
Modified by:
Jack Lee
jacklee (jack.lee at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO281 - Merge from branch 3.2.x
Handle the case where the min or max range constraints is not set
Modified
File: trunk/Providers/SDF/Src/Provider/BinaryReader.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/BinaryReader.cpp?view=diff&rev=155&p1=trunk/Providers/SDF/Src/Provider/BinaryReader.cpp&r1=154&p2=trunk/Providers/SDF/Src/Provider/BinaryReader.cpp&r2=155
File: trunk/Providers/SDF/Src/Provider/BinaryWriter.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/BinaryWriter.cpp?view=diff&rev=155&p1=trunk/Providers/SDF/Src/Provider/BinaryWriter.cpp&r1=154&p2=trunk/Providers/SDF/Src/Provider/BinaryWriter.cpp&r2=155
File: trunk/Providers/SDF/Src/Provider/BinaryWriter.h https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/BinaryWriter.h?view=diff&rev=155&p1=trunk/Providers/SDF/Src/Provider/BinaryWriter.h&r1=154&p2=trunk/Providers/SDF/Src/Provider/BinaryWriter.h&r2=155
File: trunk/Providers/SDF/Src/Provider/SchemaDb.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SchemaDb.cpp?view=diff&rev=155&p1=trunk/Providers/SDF/Src/Provider/SchemaDb.cpp&r1=154&p2=trunk/Providers/SDF/Src/Provider/SchemaDb.cpp&r2=155
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
