[fdo][FDO285][Modified] Flush and synch data one class at a time
Badreddine Karoui
badreddine.karoui at autodesk.com
Wed Nov 15 17:28:18 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO285
Type:
Defect
Artifact ID:
FDO285 (Flush and synch data one class at a time)
Modified by:
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
This updates minimize the lock contention between reader threads and the single writer thread if one exist.
The threading capability is also fixed by this updates as it was advertizing as it supports per command threaded which is not the case as the SDF provider is per connection threaded.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
