[fdo][FDO286][New] MYSQL: Insert.Execute into a Foreign Schema returns a null F...
Barbara Zoladek
barbara.zoladek at autodesk.com
Wed Nov 15 17:33:21 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO286
Type
Defect
Artifact ID
FDO286 (MYSQL: Insert.Execute into a Foreign Schema returns a null Feature Reader)
Reported by
Barbara Zoladek
barbarazoladek (barbara.zoladek at autodesk.com)
New artifact details:
- Defect Severity set to new value
Medium
- Artifact created
- Summary set to new value
- Artifact Status set to new value
New
- Description set to new value
Connect to the database without FDO metaschema
insert a feature as defined below
execute the insert command
try to read the feature reader
Nothing is returned, the feature reader is empty.
EXPECTED RESULT: the feature reader should have the feature inserted by the insert.execute command
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
