[fdo][FDO305][New] Fixed defect: ODBC failed to load layer when a property name...
Romica Dascalescu romica.dascalescu at autodesk.com
Fri Nov 24 17:48:07 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO305
Type
 Defect
Artifact ID
 FDO305 (Fixed defect: ODBC failed to load layer when a property name contains special characters.)
Reported by
 Romica Dascalescu
 romicadascalescu (romica.dascalescu at autodesk.com)
New artifact details:
- Artifact created
- Description set to new value
  Column is searched using generated name and if is not found is searched using
the real column name.
- Summary set to new value
- Artifact Status set to new value
  New
- Submission Reviewed set to new value
  Yes
- Defect Severity set to new value
  Low
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
