[fdo][FDO305][User] Fixed defect: ODBC failed to load layer when a property name...
Romica Dascalescu
romica.dascalescu at autodesk.com
Fri Nov 24 17:48:25 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO305
Type:
Defect
Artifact ID:
FDO305 (Fixed defect: ODBC failed to load layer when a property name contains special characters.)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Assigned to:
romicadascalescu
-- New value added to attribute Reviewer:
brentrobinson
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
