[fdo][FDO305][Modified] Fixed defect: ODBC failed to load layer when a property name...
Romica Dascalescu
romica.dascalescu at autodesk.com
Fri Nov 24 18:00:24 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO305
Type:
Defect
Artifact ID:
FDO305 (Fixed defect: ODBC failed to load layer when a property name contains special characters.)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO305 Fixed defect: ODBC failed to load layer when a property name contains special characters
Modified
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp?view=diff&rev=534&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp&r1=533&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp&r2=534
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
