[fdo][FDO307][Modified] Fixed XML writer: when data values contains specials charact...
Romica Dascalescu romica.dascalescu at autodesk.com
Tue Nov 28 09:29:39 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO307
Type:
Defect
Artifact ID:
FDO307 (Fixed XML writer: when data values contains specials characters)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO307 Fixed XML writer: when data values contain specials characters
Modified
File: branches/3.2.x/Fdo/UnitTest/sc1a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/UnitTest/sc1a_master.txt?view=diff&rev=547&p1=branches/3.2.x/Fdo/UnitTest/sc1a_master.txt&r1=546&p2=branches/3.2.x/Fdo/UnitTest/sc1a_master.txt&r2=547
File: branches/3.2.x/Fdo/UnitTest/sc2a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/UnitTest/sc2a_master.txt?view=diff&rev=547&p1=branches/3.2.x/Fdo/UnitTest/sc2a_master.txt&r1=546&p2=branches/3.2.x/Fdo/UnitTest/sc2a_master.txt&r2=547
File: branches/3.2.x/Fdo/Unmanaged/Src/Common/Xml/Writer.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Common/Xml/Writer.cpp?view=diff&rev=547&p1=branches/3.2.x/Fdo/Unmanaged/Src/Common/Xml/Writer.cpp&r1=546&p2=branches/3.2.x/Fdo/Unmanaged/Src/Common/Xml/Writer.cpp&r2=547
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
