[fdo][FDO307][Modified] Fixed XML writer: when data values contains specials charact...
Romica Dascalescu
romica.dascalescu at autodesk.com
Tue Nov 28 10:45:58 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO307
Type:
Defect
Artifact ID:
FDO307 (Fixed XML writer: when data values contains specials characters)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO307 Fixed XML writer: when data values contain specials characters (merged from branch)
Modified
File: trunk/Fdo/UnitTest/sc1a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/sc1a_master.txt?view=diff&rev=548&p1=trunk/Fdo/UnitTest/sc1a_master.txt&r1=547&p2=trunk/Fdo/UnitTest/sc1a_master.txt&r2=548
File: trunk/Fdo/UnitTest/sc2a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/sc2a_master.txt?view=diff&rev=548&p1=trunk/Fdo/UnitTest/sc2a_master.txt&r1=547&p2=trunk/Fdo/UnitTest/sc2a_master.txt&r2=548
File: trunk/Fdo/Unmanaged/Src/Common/Xml/Writer.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Common/Xml/Writer.cpp?view=diff&rev=548&p1=trunk/Fdo/Unmanaged/Src/Common/Xml/Writer.cpp&r1=547&p2=trunk/Fdo/Unmanaged/Src/Common/Xml/Writer.cpp&r2=548
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
