[fdo][FDO170][Modified] Fix memory leaks in the providers
Romica Dascalescu
romica.dascalescu at autodesk.com
Tue Nov 28 10:52:00 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO170 - Fix memory leaks in the ODBC provider (merged from branch)
Modified
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/DescribeSchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/DescribeSchemaTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/DescribeSchemaTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/DescribeSchemaTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.h?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.h&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAdvancedSelectTest.h&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.h?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.h&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectTest.h&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectionInfoTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectionInfoTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectionInfoTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectionInfoTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectionInfoTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectionInfoTest.h?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectionInfoTest.h&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConnectionInfoTest.h&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoImportExportTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoImportExportTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoImportExportTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoImportExportTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.h?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.h&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.h&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectionInfoTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectionInfoTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectionInfoTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectionInfoTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoDeleteTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoDeleteTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoDeleteTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoDeleteTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoInsertTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoInsertTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoInsertTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoInsertTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSchemaTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSchemaTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSchemaTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSelectTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSqlCmdTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSqlCmdTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSqlCmdTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoSqlCmdTest.cpp&r2=402
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoUpdateTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoUpdateTest.cpp?view=diff&rev=402&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoUpdateTest.cpp&r1=401&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoUpdateTest.cpp&r2=402
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
