[fdo][FDO170][Modified] Fix memory leaks in the providers
Romica Dascalescu
romica.dascalescu at autodesk.com
Tue Nov 28 11:00:41 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO170 Fixed memory leaks found with Purify in MySQL provider (merged from branch)
Modified
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/DataTypeTests.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/DataTypeTests.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/DataTypeTests.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/DataTypeTests.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationDeleteTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationDeleteTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationDeleteTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationDeleteTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoCapabilityTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoCapabilityTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoCapabilityTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoCapabilityTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoConstraintsTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.h?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.h&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.h&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoMultiThreadTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoMultiThreadTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoMultiThreadTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoMultiThreadTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.h?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.h&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.h&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/GeometryTests.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/GeometryTests.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/GeometryTests.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/GeometryTests.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/SelectTests.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/SelectTests.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/SelectTests.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/SelectTests.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectionInfoTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectionInfoTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectionInfoTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoConnectionInfoTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoDatastoreTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoDatastoreTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoDatastoreTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoDatastoreTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.h?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.h&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoAdvancedSelectTest.h&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp&r2=403
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.h?view=diff&rev=403&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.h&r1=402&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.h&r2=403
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
