[fdo][FDO311][Modified] Add property to schema causes excessive memory usage
Brent Robinson brent.robinson at autodesk.com
Wed Nov 29 12:55:56 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO311
Type:
Defect
Artifact ID:
FDO311 (Add property to schema causes excessive memory usage)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Assigned
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
